gottfried.komaier(at)gmx. Guest
Posted: Wed Feb 22, 2006 2:05 pm Post subject: AW: 914 Fuel Pumps. |
Mike,
Here is the way I'll doing. I have the mechanical pump as a standby-pump on
the engine. The fuel is going through the pump all the time in bypass, that
means all the fuel which is going through the mechanical pump goes via a
electrical valve back to the tank. In an electrical emergency, the valve
closes and the pump keeps the engine running up to ~2000m and ~55% power.
The fuel-pressure (Airbox pressure + 0,35 bar) is secured up to this
altitude and power setting. You can check the Airbox-Differential-pressure
with the new "uma"-gauge. www.umainstruments.com This instrument is the only
indicator for the fuel pressure on 914 engines which makes sense.
For checking the bypass-system the electrical pumps can switched off
momentarily after engine start.
Gottfried
-----Ursprngliche Nachricht-----
Von: owner-europa-list-server(at)matronics.com
[mailto:owner-europa-list-server(at)matronics.com] Im Auftrag von MICHAEL
PARKIN
Gesendet: Mittwoch, 22. Februar 2006 21:52
An: Europa-List(at)Matronics.Com
Betreff: 914 Fuel Pumps.
--> <mikenjulie.parkin(at)btopenworld.com>
I am not sure whether it was Europa or not, but I heard that someone was
investigating putting the manual fuel pump on the 914 with electrical back
up pumps for the high demand situation. Sounds like a good idea to me.
Does anyone know anything about it.
regards,
Posted: Wed Feb 22, 2006 2:14 pm Post subject: AW: 914 Fuel Pumps. |
Tony,
all the 914 have the eccenter for the pump-drive installed.This is the
status since around 2003. I can't say how the situation was before.
Gottfried
[mailto:owner-europa-list-server(at)matronics.com] Im Auftrag von Tony
Krzyzewski
Gesendet: Mittwoch, 22. Februar 2006 22:56
An: europa-list(at)matronics.com
Betreff: Re: 914 Fuel Pumps.
With regard to putting a mechanical pump back on to the 914.
I investigated this some time ago and found that non of the pump drive
gearing is present in the 914 gearbox so it would be a major mod
Tony.
tonyk(at)kaon.co.nz Guest
Posted: Wed Feb 22, 2006 5:22 pm Post subject: AW: 914 Fuel Pumps. |
Gottfried
Thanks for the update re the pump fitting. Mine is an earlier engine and all I have is an empty space under the cover where the mechanical pump would sit.
Tony
mikenjulie.parkin(at)btop Guest
Posted: Wed Feb 22, 2006 7:58 pm Post subject: AW: 914 Fuel Pumps. |
Tony,
My aircraft predates 2003 also - another busted flush I guess.
regards,
MP
Posted: Thu Feb 23, 2006 2:22 am Post subject: AW: 914 Fuel Pumps. |
Patrick,
The reason why the mechanical pump is the backup and not the other way round
is easy to explain:
The mechanical pump do not deliver as much pressure as the electrical one.
On the 914 you will need an fuel pressure of
Airboxpressure + 0,25 bar , 3,63
psi(normal)
Airboxpressure + 0,15 bar , 2,18
psi(minimum)
Airboxpressure + 0,35 bar , 5,08
psi(maximum)
At Take Off the engine produce an manifold pressure of 1350 hPa = 39,9 in.Hg
= 19,6 psi
That means, you need a max. Fuel pressure at the carburetor of 24,7
psi!!!!!!
The mechanical pump delivers 0,15 bar up to 0,4 bar(5,8 psi). Do you see
that difference?!
That's the reason why the mechanical pump can feed the engine only up to
~2000m with ~55% power and can works in this situation only as an EMERGENCY
equipment to bring you with reduced power to an airfield. . (Better than
nothing!!!)
You have a fine explanation of the Fuel pressure system in the Maintenance
Manual on pages 34&35
I hope this helps and bring a little light in the complicated 914 fuel
system. This is one of the reason, why the 914 is
so much expansive vs.the 912S
All the best,
Gottfried
BEBERRY(at)aol.com
Gesendet: Donnerstag, 23. Februar 2006 10:16
Why should the mechanical pump ( if you can fit one) be the 'back up pump?
It would seem sensible to adopt general G.A., practise and have a
permanently running mechanical pump and electrical back ups which are used
only for take off and when below 3000ft on the approach.?????
Patrick
BEBERRY(at)aol.com Guest
Posted: Thu Feb 23, 2006 2:37 am Post subject: AW: 914 Fuel Pumps. |
Thanks Gottfried for your explanation - very useful for a non techie ( at
least on fuel systems, pressures etc)..
Patrick
Gilles.Thesee(at)ac-greno Guest
Posted: Thu Feb 23, 2006 1:40 pm Post subject: AW: 914 Fuel Pumps. |
Quote: | That's the reason why the mechanical pump can feed the engine only up to
nothing!!!)
Gottfried and all,
Not sure I clearly understand your setup : are you intending to add a
mechanical pump to the two electrical pumps ?
So that is 3 fuel pumps, correct ?
Have you already run your engine with the mechanical pump ? If I recall
correctly, no one mentioned the possibility of upsetting the delicate
enrichment algorithm that protects the engine against detonation. The
need for the wastegate servo "disconnect switch" might come from
instabilities when the TCU little brain loses control.
I tried not to modifiy the Rotax 914, but designed the electrical
architecture so that each pump has a truly independent source of power.
This way I can insure redundant fuel delivery.
Gilles Thesee
Grenoble, France
http://contrails.free.fr
Posted: Thu Feb 23, 2006 4:38 pm Post subject: AW: 914 Fuel Pumps. |
Mike,
thank you for your discussion-input. As we see, the mechanical fuel pump
helps only in an electrical total failure (which will be on an 914-driven
aircraft an "EMERGENCY") and can bring you in this situation - and only in
that - safely to the ground.
To see the fuel pressure of the mechanical pump more exactly, we have to
consider that the pressure would be higher as laid down in the manual,
because there is no open return line back to the tank. This means, the
available power-situation would be better in an emergency.
Gottfried
PARKIN
Gesendet: Donnerstag, 23. Februar 2006 23:57
Quote: | At Take Off the engine produce an manifold pressure of 1350 hPa = 39,9
in.Hg = 19,6 psi
psi!!!!!!
see that difference?!
Gottfried,
But that 24,7 psi includes the local atmospheric pressure. Consider
pressure at sea level on an ISA day. If the atmospheric pressure was 1013
hpa, then the fuel pump pressure required would be (1350+250)-1013 = 587 hpa
(8.5psi) this as you correctly say is beyond the capability of the
mechanical fuel pump. (Ref - Maintenance Manual p34). However, that is a
max power calculation.
If one considers the max continuous condition as quoted in the operating
manual - 5000 rpm, 31 in/hg, the situation with just the mechanical pump
would be considerably better and certainly sufficient to continue to a
diversion without a problem - all be it at a fairly low altitude.
Example:
Condition - 75% power, 5000 rpm, 31 in/hg. Air box pressure = 1049 hpa.
therefore fuel pump pressure required at 1000 ft (ISA day) - (ambient
pressure = 976 hpa)
(1049+250)-976 = 324 hpa which is 4.7 psi.
Using the minimum pressure required of 0,15 bar a calculated fuel pressure
required from the mechanical pump would be 3.2 psi.
Plainly, pressure altitude is the driving factor here.
kind regards,
Mike (G-JULZ)
