Altimeter Question
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List
currydon(at)bellsouth.net
PostPosted: Sun Oct 28, 2007 3:11 pm    Post subject: Altimeter Question Reply with quote
I’m considering replacing the standard, 3-pointer altimeter in my single-engine aircraft with a counter-pointer type. The candidates are an AeroMech 8141B, an ARC EA-801, and an ARC EA-401. Does anybody know these altimeters and/or have any advice on making this change? Since all three counter-pointer altimeters are the encoding type, I would have to remove my Transcal SSD-120-30K encoder. Is that a wise move? Does anybody have the pin-outs for the cannon-plug on the backs of these altimeters?
Thanks in advance,
Don
- The Matronics Avionics-List Email Forum -
http://www.matronics.com/Navigator?Avionics-List
reichec
PostPosted: Sun Oct 28, 2007 3:41 pm    Post subject: Altimeter Question Reply with quote
Encoding altimeters are VERY EXPENSIVE to maintain as a altimeter/encoder system. It is much cheaper in the long run to keep these separate. Call up Kelley Instruments and ask how much an overhual is on one of those units... you can buy alot of regular altimeters and encoders for the price of 1 encoding altimeter overhaul. That Trans cal ssd-120 should last a long life for you.
As an avionics tech and installer, I emplore you to keep your 3 pointer system with separate encoder. Save yourself the heartache of failed pitot static inspections and costly overhaul bills down the road.
Charles Reiche
PostPosted: Mon Oct 29, 2007 3:00 am    Post subject: Altimeter Question Reply with quote
Would it be possible (or legal) to bypass the new altimeter’s internal encoder and retain the Transcal encoder?
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List All times are GMT - 8 Hours
