Larry Bowen
Posted: Tue Aug 21, 2007 1:30 pm Post subject: Tail wheel question |
I match drilled the horizontal holes instead.
http://bowenaero.com/mt3/2006/04/tailwheel_upgra.html
Larry Bowen
Larry(at)BowenAero.com (Larry(at)BowenAero.com)
http://BowenAero.com
On 8/21/07, PeterHunt1(at)aol.com (PeterHunt1(at)aol.com) <PeterHunt1(at)aol.com (PeterHunt1(at)aol.com)> wrote: [quote] I just purchased the 6" double fork tail wheel from Aviation Products, Inc. to give me increased clearance over Van's tail wheel. It appears to have a vertical pilot hole which I must use to drill a new vertical hole through the tailspring onto which it mounts.
1. Are there any tricks/suggestions for drilling this hole?
2. Can this be easily and accurately done with the tailspring still installed on the airplane?
3. Is the one vertical hole adequate or should I try to match up the two horizontal holes which Vans has in their tailspring and drill them too?
I understand many of you have installed this upgrade tail wheel and I would appreciate hearing of your experience.
Further, the new tail wheel weighs 5 pounds (bathroom scale). I haven't removed my Van's tail wheel yet, but suspect the new one is heavier and will change my CG. Any thoughts?
Pete in Clearwater
RV-6 tip-up with all electric panel
2006 SnF Reserve Grand Champion - Kit
2007 SnF Outstanding Aircraft Award - Homebuilt
AOL.com.
[quote][b] http://www.matronics.com/Navigator?RV-List http://forums.matronics.com [quote][b]
_________________ Larry Bowen
RV-8 SOLD,
RV-7QB in progress... |
