prop bolts
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Engines-List
dj45
PostPosted: Fri Jul 27, 2007 8:37 am    Post subject: prop bolts Reply with quote
Can anyone tell me what the tourque on prop bolts should be? IO360 w/ alum prop.
- The Matronics Engines-List Email Forum -
http://www.matronics.com/Navigator?Engines-List
Dan Stanton
N801S CH 801
N226BS CH701
N24DS CH750
apilot2(at)gmail.com
PostPosted: Fri Jul 27, 2007 3:55 pm    Post subject: prop bolts Reply with quote
Fixed or constant speed, what brand prop? Seems like my Hartzell came
with instructions on torque, but maybe it was in the Lycoming overhaul
manual as well.
Dan Stanton
90% done 90% to go
801, IO360
http://forums.matronics.com/viewtopic.php?p=125903#125903
dj45
PostPosted: Fri Jul 27, 2007 6:21 pm    Post subject: Re: prop bolts Reply with quote
Senscnech(?) prop fixed pitch
Dan Stanton
N801S CH 801
N226BS CH701
N24DS CH750
glcasey
PostPosted: Sat Jul 28, 2007 4:15 am    Post subject: prop bolts Reply with quote
My instruction manual said 60-65 ft-lb, clean and dry. They put
emphasis on the threads being dry, not lubricated. If the threads
are lubricated the proper torque would be lower, but I don't know how
low. This was for an Aerocomposites prop on an IO-540, but I believe
the hubs and bolts are the same for all Lycomings with constant-speed
props.
Gary Casey
> w/ alum prop.
> Thanks
> Dan Stanton
> 90% done 90% to go
> 801, IO360
Gary Casey
Float Flyr
PostPosted: Sat Jul 28, 2007 6:56 am    Post subject: prop bolts Reply with quote
If you accidentally get some oil or grease in the threads you can wash it
out with a bit of MEK.
Noel
[quote] --
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
esmith6(at)satx.rr.com
PostPosted: Sat Jul 28, 2007 8:37 am    Post subject: prop bolts Reply with quote
Dan...........Contact Sensenich Prop. Mfg. Co., 14 Citation Ln., Lititz, Pa.
17543......719-569-0435......or email Engineer Dave Burkhart
daveb(at)sensenich.com They will be glad to answer your
questions.................CHEERS!!!!.....and good luck!
Gene Smith
RV-4 14yrs.
dfultz7(at)earthlink.net
PostPosted: Sat Jul 28, 2007 8:49 am    Post subject: prop bolts Reply with quote
Gene,,The correct phone number is 717-569-0435
PostPosted: Sat Jul 28, 2007 9:40 am    Post subject: prop bolts Reply with quote
Dale, you are correct, and thanks.........Dan, sorry, hope that little digit
didn't screw your plans up too much...I don't think they are open on
Saturdays any way?.........CHEERS!!!!
Please do not ARCHIVE!
dj45
PostPosted: Sat Jul 28, 2007 5:49 pm    Post subject: Re: prop bolts Reply with quote
Thank you every one. I think I have a handle on it now.
Dan Stanton
N801S CH 801
N226BS CH701
N24DS CH750
dj45
PostPosted: Sat Jul 28, 2007 5:52 pm    Post subject: Re: prop bolts Reply with quote
You know, sometimes these planes start to get complacated. Way too many details to keep track of for an old man.
Dan Stanton
N801S CH 801
N226BS CH701
N24DS CH750
AzevedoFlyer(at)aol.com
PostPosted: Sun Jul 29, 2007 2:48 pm    Post subject: prop bolts Reply with quote
Don,
I0360 and O320 share the same prop.
Assuming yours to be 3/8" bolt diameter, the torque is 24 to 25 lbf.ft.
Bolts must be dry, non lubricated.
Got this piece of info from Sensenich themselves.
Cheers,
Miguel Azevedo
PA22/20
Float Flyr
PostPosted: Sun Jul 29, 2007 5:29 pm    Post subject: prop bolts Reply with quote
Keep the lockwire nice and tight too.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
jrccea(at)bellsouth.net
PostPosted: Mon Jul 30, 2007 7:08 am    Post subject: prop bolts Reply with quote
Please double check this. They usuallly do not share the same prop. Among other things, the bolt hole diameter in the O and IO-360's is usually larger.
JimC
azevedoflyer(at)aol.com
PostPosted: Mon Jul 30, 2007 3:01 pm    Post subject: prop bolts Reply with quote
Jim,
You are absolutely right!
What I checked was 0320-150 hp and 0320-160hp (high compression)! Those two use the same prop.
Maybe I got sidetracked by 160hp and 0360!
I am sorry I fed the list a mistaken info and charged Sensenich for it!
Must be one of those senior moments...
Hope no damage was done.
Miguel Azevedo
PA22/20-150
PostPosted: Mon Jul 30, 2007 6:31 pm    Post subject: prop bolts Reply with quote
None here. I have more and more of those senior moments myself. Good to know I don't have a monopoly on it.
Jim
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Engines-List All times are GMT - 8 Hours
