		Float Flyr
				 Posted: Fri Jul 06, 2007 8:57 am    Post subject: carb or fuel injection? turbo? |
				Could it be that the turbo is designed primarily to maintain full power at
 altitude?  Or possibly to allow the engine to operate at far greater
 altitudes.
 Consider also the removal of carb heat and the possibility of icing.
 Noel
 [quote] --
  |  | - The Matronics Engines-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?Engines-List |
  _________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
		grosseair(at)comcast.net Guest
				 Posted: Fri Jul 06, 2007 10:20 am    Post subject: carb or fuel injection? turbo? |
				Injected eliminates carb heat issues and almost all induction icing
 issues. It's also more efficient and seems to be pretty much universal
 on higher performance engines although it is more expensive. On a IO-360
 the turbocharging is actually turbo-normalizing which means that it
 allows you to develop more horsepower at higher altitudes. The only
 stock turbochargers I'm aware of have a fixed waste gate which is not
 particularly effective. There is an stc'd turbo charger made by Rajay
 for the IO-360 that is much better but it's also about $10,000 last time
 I looked several years ago. There are also substantially higher
 maintenance costs associated with turbo charging although I think your
 800 hour TBO is probably on the turbo and not the entire engine.
 The bottom line for me was that a turbo might be worth the added expense
 and complexity if you live in the mountains of the West or regularily
 fly out there but not for me living in the flat lands of the Midwest. If
 I did get a turbo it would not be the one with a fixed waste gate. I'd
 spend the bucks for a Rajay.
 just my 2 cents.
 John
 T22 wrote:
 Does anybody have any insight on pros/cons of carberator versus fuel injection?  How about adding a turbo?  Lycoming's website for 360 engines (see link below) lists the turbocharged injected engine at 800hours (40%) less TBO plus 100lbs additional weight for only 20HP gained.
 http://forums.matronics.com/viewtopic.php?p=122513#122513
		longg(at)pjm.com Guest
				 Posted: Fri Jul 06, 2007 11:24 am    Post subject: carb or fuel injection? turbo? |
				John et al,
 	I would note that if you like to fly high the turbo/super will
 help you get there faster with reduced power loss and consistent climb.
 Even if you live in the east or mid-west there is a cost to the climb.
 My old Piper with the O-320 was a great plane, but you'd spend the weeks
 paycheck in fuel getting to 10k and if it was the middle of summer,
 you'd have to flatten out every 10-15 so you wouldn't melt the heads.
 	There are plenty of advantages and, as John said a cost to turbo
 systems. I am building a Lancair Legacy and will use a supercharged
 Subaru. Superchargers have their own pros and cons. The greatest
 advantage of the supercharger is the no-lag response and minimal heat
 issues. On the turbo systems, the exhaust system is complex and ouch -
 it gets very hot which leads to shorter life and more $$$ on exhaust
 pipe. If you go with the Subaru turbo, you can actually loose the
 exhaust system and just use a short pipe.
 	The people with the most experience in Lycoming turbos' has to
 be Lancair. You just don't buy these of the shelf. They will sell you a
 TNIO-390X with for 40k. All of their machine work is done on the
 premises. They do great work. My Subaru which will also put out 210-220
 HP FWF is about $25k.
		NYTerminat(at)aol.com Guest
				 Posted: Fri Jul 06, 2007 1:21 pm    Post subject: carb or fuel injection? turbo? |
				In a message dated 7/6/2007 3:25:11 P.M. Eastern Daylight Time,  longg(at)pjm.com writes:
   	  | Quote: | 	 		  The    people with the most experience in Lycoming turbos' has to
  Is that for the Eggenfeller  package?
 See what's free at AOL.com.
		grant.piper(at)bigpond.co Guest
				 Posted: Fri Jul 06, 2007 2:59 pm    Post subject: carb or fuel injection? turbo? |
				I would like to add that another option is an Ellison Throttle Body Injector
 'carburettor'.   If well set up, you can lean as well as FI without the
 cost, weight and complexity of FI.   The CAFE Mooney runs an IO-360-A1B6
 with an Ellison rather than FI.   Check their 'site for details.   An
 Ellison also means only a low pressure fuel pump is needed, thus less cost
 again, and no fuel return line is needed, so plumbing is easier also.   Carb
 heat is recommended with them, but they are less susceptible to icing than a
 standard carb, and you need/should have alternate air with FI anyway.
 Just to be clear, FI as used on aircraft is not EFI as used on cars.   FI is
 all mechanical.
 Grant Piper
		Float Flyr
				 Posted: Fri Jul 06, 2007 3:57 pm    Post subject: carb or fuel injection? turbo? |
				Is the Ellison system also what used to be referred to as a pressure
 carburettor?
 Noel
 [quote] --
Kitfox III-A
		purplemoon99(at)bellsouth Guest
				 Posted: Fri Jul 06, 2007 4:17 pm    Post subject: carb or fuel injection? turbo? |
				If you are running a subaru, and thinking about supercharger you should talk
 to Ron at RAM  ,If anybody knows supercharging a subaru it would be Ron..
 Joe N101HD 601 XL
		apilot2(at)gmail.com Guest
				 Posted: Fri Jul 06, 2007 6:10 pm    Post subject: carb or fuel injection? turbo? |
				No. Pressure carbs were most commonly used on Bonanzas. They are a
 very sophisticated carb that functions like an altitude compensated
 throttle body injection.
 Several erroneous pieces of info already mentioned.
 The difference between a 180hp O-360 and 200 hp IO-360 is about 35
 lbs, not 100. The injected engine will run LOP, most with stock
 injectors. A carb won't without some extra effort to vaporize the fuel
 and that takes heat, which reduces power.  The difference in TBO is
 ZERO, NADA,ZIP.  Both are 2000 hour TBO. The difference in power is
 most felt for takeoff and climb, much less in cruise.
 A throttle body injection like the Ellison is susceptible to throttle
 icing, and won't have as good mixture distribution as a port injection
 system like the Bendix. Bendix system is very simple, no user
 adjustments beyond idle speed and mixture, minimal maintenance, very
 reliable.
 KM
 A&P/IA
  carburettor?
  Noel
				 Posted: Sat Jul 07, 2007 12:30 am    Post subject: carb or fuel injection? turbo? |
				Hi Noel,
 No, it uses a diaphram that opens with airflow to supply fuel to the
 metering tube with many small holes in it extending acroos the carb. throat.
 A flat slide (the throttle) uncovers the tube, and thus more holes, as you
 open the throttle.   The mixture is adjusted by rotating the metering tube
 so that the holes face into the airflow (full lean) or ~90° to the airflow
 (full rich).   There is also a separate simple mixture circuit for idle
 adjustment.   There is no float bowl, so it doesn't care which way up it is.
 It will work with gravity or low pressure (2-6psi) fuel supply.   They are
 susceptible to hiccups with hot fuel vaporising on the ground due to having
 no float bowl to separate the fuel from the vapour, but I have found it
 clears immediately high power/fuel flow is demanded.   Hot starts are
 excellent cf. FI.   I think they are a good thing, but there aren't a great
 number of people using them so there is little corporate knowledge out there
 about them.   I like the lightness and simplicity, and will live with the
 odd hiccup when hot.
 Grant Piper
		Float Flyr
				 Posted: Sat Jul 07, 2007 7:52 pm    Post subject: carb or fuel injection? turbo? |
				Thanks I'll Google Elliston and have a closer look.
 Noel
 [quote] --
Kitfox III-A
