reserve fuel
raimo.toivio(at)rwm.fi
PostPosted: Thu Feb 09, 2006 6:18 am    Post subject: reserve fuel Reply with quote
I am making placards and just a fast Q;
Europa XS fuel tank total capacity
is 70 litres including reserve. How
many litres is a reserve side, about?
Just wonder how many minutes it takes
to get an answer! Thank you!
Raimo M W Toivio
OH-XRT #417 1400 hrs so far, engine installation
OH-CVK C172 Skyhawk
OH-BLL Beechcraft C45 w radial engines (grounded)
37500 Lempaala
Finland
tel + 358 3 3753 777
fax + 358 3 3753 100
gsm + 358 40 590 1450
www.rwm.fi
ptag.dev(at)tiscali.co.uk
PostPosted: Thu Feb 09, 2006 6:54 am    Post subject: reserve fuel Reply with quote
Hi! Raimo
Just so you have a quick answer I'd say approx 2 gallons which is just
over 9 litres but with the a/c in cruise level it may be slightly more.
Bob H G-PTAG Europa MKI/Jabiru3300
Robt.C.Harrison
rholder(at)avnet.co.uk
PostPosted: Thu Feb 09, 2006 7:18 am    Post subject: reserve fuel Reply with quote
I am making placards and just a fast Q; Europa XS fuel
tank total capacity is 70 litres including reserve. How
many litres is a reserve side, about? Just wonder how
many minutes it takes to get an answer! Thank you!
You need to measure yours.
Mine is 9 litres on the reserve side if the aircraft is
not being thrown around in turbulence. Less if it is bumpy !
Richard
Was that quick enough ? Smile
cassel(at)sensewave.com
PostPosted: Thu Feb 09, 2006 7:24 am    Post subject: reserve fuel Reply with quote
Hi Raimo,
About 10 liter if I remember correct.
But it may be much less, especially if you got a 912/912S with less return
fuel then 914 Turbulence may move fuel from reserve to main.
Remember that is one tank including "reserve".
Please land before your "main" is empty
Stephan
LN-STE #556
Raimo M W Toivio
OH-CVK C172 Skyhawk
37500 Lempaala
Finland
www.rwm.fi
topglock(at)cox.net
PostPosted: Thu Feb 09, 2006 8:30 am    Post subject: reserve fuel Reply with quote
Measured ours at 2.6 US Gallons, with fuselage leveled...
Rman - N55XS
140 hours
Raimo M W Toivio
OH-CVK C172 Skyhawk
37500 Lempaala
Finland
www.rwm.fi
PostPosted: Thu Feb 09, 2006 9:13 am    Post subject: reserve fuel Reply with quote
Thanks for every one for nice, kind and fast answers.
So, if you manage to land using main tank only, you
have maybe in theory 45 minutes reserve time left
(Rotax minimum consumption about 12 litres/hour),
which is a demand of VFR rules...
Regards, Raimo
nigelcharles(at)tiscali.c
PostPosted: Thu Feb 09, 2006 10:59 am    Post subject: reserve fuel Reply with quote
There is a variation between individual tanks. Mine has 9 litres.
Nigel Charles
PostPosted: Fri Feb 10, 2006 1:46 am    Post subject: reserve fuel Reply with quote
Engine manual page 6-3
confirms it - 9 litres.
Should I read manual more!
Raimo
