dmaib@me.com
Joined: 25 Apr 2006 Posts: 455 Location: New Smyrna Beach, Florida
Posted: Thu Apr 26, 2007 3:04 am Post subject: Hot Tunnels |
I have not seen anything about hot tunnels for a long time now. I am curious to know if any -10 flying with the Sam James cowl (maybe just one flying so far?) has hot tunnel problems. How about anybody flying with the firewall insulated on the front side? This was such a huge issue just a few months ago and now is completely quiet. Did I miss out on the miracle cure?
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
Tim Olson
Posted: Thu Apr 26, 2007 3:50 am Post subject: Hot Tunnels |
I never had it where I could call it hot, except it did get
pretty warm by the heater outlets in the cabin when there was
heat on either front or rear. But, during my inspection this
year I decided that with hot air SCAT tubes in close prox. to
fuel lines and fuel valves, it would be nice to do more, so I
wrapped my SCAT tubes with the same silver reflective insulation
that's foam/fiber filled as I used on the firewall. The result
was a week or two ago I went barefoot and felt the tunnel and
it was almost not even noticeably warm. I insulated back to
the fuel valve. That gives me a little more margin for warmth
against that tunnel being warm enough to vaporize the fuel.
But, I didn't do it because of a problem, just because it seemed
prudent.
dmaib(at)mac.com wrote:
-------- David Maib RV-10 #40559
http://forums.matronics.com/viewtopic.php?p=109323#109323
GRANSCOTT(at)aol.com Guest
Posted: Thu Apr 26, 2007 4:12 am Post subject: Hot Tunnels |
In a message dated 4/26/2007 7:53:05 AM Eastern Daylight Time, Tim(at)MyRV10.com writes:
| Quote: | I insulated back to
prudent. |
Tim with the ambient air now on a warming cycle in your area do you think the relatively cool winter air may have aided in the cooling effect?
Patrick
See what's free at AOL.com.
dmaib@me.com
Posted: Thu Apr 26, 2007 4:15 am Post subject: Hot Tunnels |
TIm, as I recall, you also had your exhaust stacks lengthened. Do you
think that is a good idea as well? Thanks for the info.
David Maib
#40559
prudent.
RV-10 #40559
Tim Olson
Posted: Thu Apr 26, 2007 5:28 am Post subject: Hot Tunnels |
I'm sure it didn't hurt, but the day I flew and was barefoot,
we had a warm week with temps in the 80's, so it was all
shorts and T-shirts and flip-flops, so while it isn't exactly
the same as being in the Desert, it at least wasn't a cold
Wisconsin day in comparison.
I think perhaps a huge factor in the hot tunnels is how well
the builder's heater control flap doors shut. If you get any
hot air flowing through that SCAT, it will get very warm
around the outlets where the SCAT hits the aluminum flange.
GRANSCOTT(at)aol.com wrote:
| Quote: | In a message dated 4/26/2007 7:53:05 AM Eastern Daylight Time,
I insulated back to
prudent.
Patrick
Tim Olson
Posted: Thu Apr 26, 2007 5:29 am Post subject: Hot Tunnels |
I don't think it's a bad idea at all. But, my stacks were made
shorter than the ones sold after them, so by my adding length,
I only made them more "normal" by newer kit's standards. So
for any builders that are far down the line from kit# 170, I
don't think you'll really want to do anything special.
David Maib wrote:
David Maib
#40559
CJohnston(at)popsound.com Guest
Posted: Thu Apr 26, 2007 7:22 am Post subject: Hot Tunnels |
along this line, i had a question about the scat tubing in the tunnel... it looks as if it is supposed to just rest on the WD-1010 control column as it passes in the tunnel. is this correct? do i need to secure this in some fashion. does the movement of the WD-1010 chafe on the scat?
questions questions
cj
#40410
fuse/finish
www.perfectlygoodairplane.net
Posted: Thu Apr 26, 2007 7:45 am Post subject: Hot Tunnels |
Of course, remember that #170 doesn't mean much on the exhaust, but rather
what date your FWF kit was shipped.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
www.saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
Tim Olson
Posted: Thu Apr 26, 2007 8:35 am Post subject: Hot Tunnels |
With it secured up in the tunnel, it really doesn't sag that far
down if you have it fit well, so if it touches, it would be
rare and only at control travel extremes. I looked at that
well during the inspection to see if there was anything
happening and there wasn't. I think it's pretty much clear
of it most of the time.
Chris Johnston wrote:
| Quote: | along this line, i had a question about the scat tubing in the
questions questions cj #40410 fuse/finish
www.perfectlygoodairplane.net do not archive
Tim Olson
Posted: Thu Apr 26, 2007 8:36 am Post subject: Hot Tunnels |
Dang, I keep forgetting that caveat. Yes, it would be based on
when you get the FWF kit. For me, it was nearing 2 years
ago now. So if yours was delivered well after that, you probably
have nothing to worry about. There are a few flying -10's
built with FWF kits after mine and they made me look like
I was the one with the short dangling things, instead of
the long ones. (but I'm used to that by now after all
these years)
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
