fitting doors
flyinggpa(at)comcast.net
PostPosted: Tue Feb 07, 2006 4:54 pm    Post subject: fitting doors Reply with quote
Jos
I did not like the big gaps in the door tangs either. I talked to Andy when I was building and he did not know why they were built the way the are, SO , I redesigned the tangs and the recesses in the top of the fuselage. I have just a small crack around the tangs the same as around the rest of the door. The hinge line was keep the same.
To do this I had to make new recesses to fit the new tangs. The tangs are squared off and the recesses are squared off too. It really is not a hard job. (just takes tine! ) I started by dremal-grinding the old recess away. Then put foam blocks in place and layers up 4 layers of bid on the inside of the top. The tangs were much harder to build. I used a little bid and a lot of flox and trial and error to get them squared off. (the hinge surface is not changed)
There are pictures some ware in my Europaowners page.
Good luck
Cliff Shaw
1041 Euclid ave.
Edmonds, WA 98020
425 776 5555
http://www.europaowners.org/WileE
SPurpura(at)aol.com
PostPosted: Tue Feb 07, 2006 6:11 pm    Post subject: fitting doors Reply with quote
It varies depending on hinges are set,trim to fit.
