		wdaniell(at)etb.net.co Guest
				 Posted: Tue Feb 07, 2006 4:14 am    Post subject: Europa Classic Test Fitting |
				Take the time you think it will take to build - add in all the f-factor you
 can think of and then double it.
 But remember that the journey is as important as the destination
 (glasshopper).
  |  | - The Matronics Europa-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Dave Miller
				 Posted: Tue Feb 07, 2006 6:28 am    Post subject: Europa Classic Test Fitting |
				Phil,
 My classic took 2,500+ hours and I would imagine that most other builders
 who work alone will put in similar time.
 At least you are well named, there will be hours and hours of "philling"
 to do on the classic wing.
 Dave A061
 "flyingphil2" <ptiller(at)lolacars.com>
 Sent by: owner-europa-list-server(at)matronics.com
 02/07/2006 04:43 AM
 Please respond to europa-list
         To:
         cc:
         Subject:        Europa Classic Test Fitting
 Hello All,
 I'm new to this forum but have just joined as I'm thinking of building a
 Europa.  I had my mind set on an XS and possibly a Hi-top but I've
 recently seen a Classic kit for sale which is unstarted.  I've had a
 flight as a passenger in a Classic and being 6'1" tall and medium (ish!)
 build I fitted in fairly well.  However, I would like to sit in a Classic
 (with/without cockpit mods (LA etc)) again before I make my mind up.
 I'm located in Northampton in the UK.  Is there any Europa Classic owner
 nearby who could spare an hour or so to let me have a look at their
 aircraft and have a sit in it please?
 Also, I've seen quite a lot of info on the net about this but could any
 Classic builders give a realistic estimate of build times for this kit.  I
 was going to go for the fastbuild option (~1000hrs) but with a Classic
 'Slowbuild' I guess I'm looking at much longer.
 Phil
		EuropaXSA276(at)aol.com Guest
				 Posted: Tue Feb 07, 2006 6:33 am    Post subject: Europa Classic Test Fitting |
				1000 hours! Whoa Phil!
 I can tell you that 1000 hours to build an XS kit is probably not realistic.
 I purchased all fast build options. With over 2 years time and 800 hours into
 the project I still have airplane pieces laying about the house. <Granted
 these pieces are now much much larger than they once were.> I'm not close to
 completion.
 My guess < and it is only that> is these are a 2000 plus hour project.  Take
 your time and enjoy the build process. < It's actually therapeutic for me> If
 that's not to your liking then buy one already built. Any way you choose you
 will have a sweet flying airplane.
 Do not Archive.
 Brian Skelly
 Europa XS TriGear #A276
 North Texas USA
 You can see my build photos at:
 www.europaowners.org/brians
		topglock(at)cox.net Guest
				 Posted: Tue Feb 07, 2006 5:18 pm    Post subject: Europa Classic Test Fitting |
				Building an XS in 1000 hours can certainly be done, though it takes a
 bit of dedication and a sense of urgency...
 I built mine is 925 hours, but I rarely had three days, in succession,
 when I wasn't doing something on the plane.  I was also fortunate enough
 to have been exposed to aircraft and related systems all my life...
 Jeff - N55XS
 140 hours and still grinning...
 EuropaXSA276(at)aol.com wrote:
 completion.
 Do not Archive.
 Brian Skelly
 North Texas USA
		SPurpura(at)aol.com Guest
				 Posted: Tue Feb 07, 2006 6:14 pm    Post subject: Europa Classic Test Fitting |
				I was a first time builder and spent 2250 hrs on my XS,600 hrs in the sanding
 and filling alone.
