canopy gas shock
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Glasair-List
helicat76(at)shaw.ca
PostPosted: Fri Apr 06, 2007 10:38 pm    Post subject: canopy gas shock Reply with quote
I have recently purchased a Glasair I and I have been trying to find a replacement for my canopy gas strut. Does anyone have any information about where a person can obtain one, or where I would get the specifications, so that I can try to get one built? I have emailed the Glasair people twice, and have had no reply, so I am assuming that they do not sell them. Any help would be appreciated. I am in Canada.
Thanks;
Shona
- The Matronics Glasair-List Email Forum -
http://www.matronics.com/Navigator?Glasair-List
rlhrlh(at)adelphia.net
PostPosted: Sat Apr 07, 2007 4:52 am    Post subject: canopy gas shock Reply with quote
Hello Helicat,
I own a Glasair III, and have replaced the gas spring several times. If
you can verify that the two canopies use the same gas spring, I will
send on the part number and ordering info.
Good Luck,
Robert L. Hunter
N957DJ
Thanks;
Shona
lists(at)stevet.net
PostPosted: Sat Apr 07, 2007 5:14 am    Post subject: canopy gas shock Reply with quote
Don't assume that the gas springs are the same for the GIII and the GI.  I can't believe that Glasair Aviation has not responded.  They are usually very responsive.  Did you try the address, parts(at)glasairaviation.com (parts(at)glasairaviation.com)?  Or call their main number and ask for the Parts Dept.  They usually don't answer the phone, but if you leave a message they will get back to you.
Best Regards,
Steve
____________________________________________________________________
Thanks;
Shona
         - The Glasair-List Email Forum class="Apple-converted-space"> --> http://www.matronics.com/Navigator?Glasair-List              - NEW MATRONICS WEB FORUMS - class="Apple-converted-space">   --> http://forums.matronics.com
Craymondw(at)aol.com
PostPosted: Sat Apr 07, 2007 5:55 am    Post subject: canopy gas shock Reply with quote
The gas shock can be found at marinas and is used on boat hatches. If you buy it from a marine supplier don't say it is for an aircraft. The reason why Glasair doesn't sell them is because once the manufacturer found they where used on A/C, they shut them off.
See what's free at AOL.com.
robin02(at)mindspring.com
PostPosted: Sat Apr 07, 2007 6:52 am    Post subject: canopy gas shock Reply with quote
Shona, the original kits were produced in the early 80’s and used a gas cylinder from Boeing. They were used on the overhead compartment doors of a discontinued plane. I have had several go bad. Measure the length of the closed cylinder when the canopy is closed and again the length when it is open. Auto parts stores sell these for rear hatch’s of small cars. They will likely not have what you need in stock but will have a chart that will list the specs you need and will special order it. The last time I bought them, I got the company name off the display and bought online. The minimum order required me to purchase three gas cylinders. Robin Young 286YM
Thanks;
Shona
[quote] [b]
Bruce(at)glasair.org
PostPosted: Sat Apr 07, 2007 8:52 am    Post subject: canopy gas shock Reply with quote
Try http://www.guden.com/dampers.asp.
Bruce
www.glasair.org
s_korney(at)hotmail.com
PostPosted: Sat Apr 07, 2007 9:28 am    Post subject: canopy gas shock Reply with quote
Shona...
Send me your canopy gas shocks and I'll recharge them for you... What
pressure would you like...
Best... Steve
----Original Message Follows----
Reply-To: glasair-list(at)matronics.com
Subject: canopy gas shock
Date: Fri, 06 Apr 2007 23:37:49 -0700
Thanks;
Shona
Need a break? Find your escape route with Live Search Maps.
http://maps.live.com/?icid=hmtag3
PostPosted: Sat Apr 07, 2007 12:29 pm    Post subject: canopy gas shock Reply with quote
From: owner-glasair-list-server(at)matronics.com [mailto:owner-glasair-list-server(at)matronics.com] On Behalf Of Bruce Gray
Sent: Saturday, April 07, 2007 12:52 PM
Subject: RE: canopy gas shock
Also www.easylift.com . RObin
Bruce
www.glasair.org
Thanks;
Shona [b]
royschechter(at)yahoo.com
PostPosted: Sat Apr 07, 2007 3:49 pm    Post subject: canopy gas shock Reply with quote
YOUR BEST BET IS A MARINE SUPPLY OUTLET. MANUFACTURED BY ATTWOOD. LISTED IN WEST MARINE CATALOG AS SPRINGLIFT GAS LIFT SUPPORTS. GET THE 40# RATING. COST ABOUT 23$.GOOD LUCK. ROY
NYTerminat(at)aol.com
PostPosted: Sat Apr 07, 2007 8:22 pm    Post subject: canopy gas shock Reply with quote
Shona, you can get gas struts from McMaster-Carr. _WWW.MCMASTER.COM_
(http://www.MCMASTER.COM) , loook under gas springs.
Bob Spudis
In a message dated 4/7/2007 10:53:29 A.M. Eastern Daylight Time,
robin02(at)mindspring.com writes:
Thanks;
Shona
(http://www.matronics.com/Navigator?Glasair-List)
************************************** See what's free at http://www.aol.com
PostPosted: Sun Apr 08, 2007 5:31 pm    Post subject: canopy gas shock Reply with quote
Thanks for all the great suggestions, I will start looking into these options!
Shona
PostPosted: Sun Apr 08, 2007 5:36 pm    Post subject: canopy gas shock Reply with quote
Thanks Steve, but there in lies the problem, I am not sure what the best
pressure would be. My most unscientific experiment with the bathroom scale
suggests somewhere around 35-40lbs, but that could be way off.
I will send you the old one, just email me a mailing address, and I'll see
if I can get a more accurate approximation of the required pressure.
Shona
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Glasair-List All times are GMT - 8 Hours
