wing kit?
slook(at)mchsi.com
PostPosted: Thu Feb 02, 2006 2:31 pm    Post subject: wing kit? Reply with quote
Howdy All,
I'm nearing the end of my tail kit and thinking about ordering my
wings. I'm looking for opinions about getting the aileron trim tab
option. How worthwhile is this? I don't know that I've even flown
anything with aileron trim.... It wouldn't hurt to save that money
for something else.
Steve
Steve Look
Monticello, IL
601XL - tail kit
"Dogs have owners, Cats have staff"
Larry McFarland
PostPosted: Thu Feb 02, 2006 3:18 pm    Post subject: wing kit? Reply with quote
Steven,
The trim tab seems a bit much initially, but when you fly a plane that
has a shorter span
and loading becomes one sided or your trim isn't exactly where it should
be to begin with, the tab
could be a worth while item. My HDS with 23-foot span is very
responsive to inputs and loading
and the tab does take the pressure off when I'm transferring fuel or
carrying someone that's 225.
I think you'll find the XL just as sensitive and is a better value with
the tab when you decide to sell.
Also there's the influx of cheaper autopilot controls that would be
helped by having electric trim tabs.
Much easier to install before than later.
I'd recommend you go for it.
Larry McFarland - 601HDS at www.macsmachine.com
Stephen R. Look wrote:
Howdy All,
for something else.
Steve
Steve Look
Monticello, IL
601XL - tail kit
Larry McFarland - 601HDS - Stratus
zodierocket(at)hsfx.ca
PostPosted: Thu Feb 02, 2006 3:36 pm    Post subject: wing kit? Reply with quote
Keep the aileron trim, it's the wing lockers that would be the optional
choice in my opinion. But I'm rather heavy set and running the 4 gas
tanks so I couldn't imagine not having the aileron trim.
Mark Townsend Alma, Ontario
Zodiac 601XL C-GOXL, CH701 just started
www.ch601.org / www.ch701.com / www.Osprey2.com
leogates(at)allvantage.co
PostPosted: Thu Feb 02, 2006 4:05 pm    Post subject: wing kit? Reply with quote
Amen to Larry's comments. I couldn't say it better.
Leo Gates
N601Z
daveaustin2(at)sprint.ca
PostPosted: Thu Feb 02, 2006 5:23 pm    Post subject: wing kit? Reply with quote
Buy the aileron trim. You will not regret it.
Dave Austin 601HDS - 912, Spitfire Mk VIII
p.mulwitz(at)worldnet.att
PostPosted: Thu Feb 02, 2006 8:23 pm    Post subject: wing kit? Reply with quote
I opted for the aileron trim. I want to be able to fly hands-off
both with and without a passenger in the other seat. I suspect the
aileron trim is the only way (short of an autopilot) to do this.
Paul
XL wings
for something else.
Steve
David X
PostPosted: Thu Feb 02, 2006 8:40 pm    Post subject: Re: wing kit? Reply with quote
It's very helpfull for two finger flying on a cross country. It helps reduce pilot fatigue and makes it easier to stay on course. I usually end up trimming it nearly all the way up until I burn off the left tank first ... if I'm the only one on board (the trim is on the left on my plane). After losing 60 or 80 pounds of fuel, I can reduce the trim (and drag).
Zodiac 601 XL - CZAW Built - Rotax 912S
DO NOT ARCHIVE
japhillipsga(at)aol.com
PostPosted: Fri Feb 03, 2006 5:55 am    Post subject: wing kit? Reply with quote
Steve, I built the XL and included the alerion trim. I use it on every flight. The XL is balanced such (probably by CH's smart design) to be a little heavy on the left side with only the PIC. Need some trim up to level her hands off. With a passenger, depending on size, trim again necessary, either way. Save money on dog and cat food, spend it on toys first ! Best regards, Bill
don.wentz(at)intel.com
PostPosted: Fri Feb 03, 2006 1:49 pm    Post subject: wing kit? Reply with quote
Steve,
Van's sells a simple spring preload aileron trim kit for the RV side by
side aircraft.
I have electric trim in my RV-6 but if I had it to do again, I'd use the
spring setup.
BTW - even with the trim, I find that I seldom use it. When flying
cross country rather than chase the fuel burn with the trim, I just fly
the thing.
Dw
RV-6 920hrs
CoJo331(at)aol.com
PostPosted: Sat Feb 04, 2006 12:46 pm    Post subject: wing kit? Reply with quote
Another option you might want to consider is if you
want the standard hingless aileron or the piano
hinged option. I believe the hingless design is
furnished if not otherwise specified happy building.
slook(at)mchsi.com
PostPosted: Mon Feb 06, 2006 1:06 pm    Post subject: wing kit? Reply with quote
Thanks to everyone who replied to my question. About 99% of responses
on-list and off said the aileron trim was a good idea so that's what
I'm going to do. Thanks again,
Steve
At 04:09 PM 2/2/2006, you wrote:
...I'm looking for opinions about getting the aileron trim tab
Steve Look
Monticello, IL
601XL - tail kit
