Subject: Monowheel Tire & Tube life
mau11(at)free.fr
PostPosted: Sun Feb 05, 2006 2:07 am    Post subject: Subject: Monowheel Tire & Tube life Reply with quote
Bonjour Rmi,
Ou as tu achet ton pneu Mc Creary 800 6/6?
En est-tu satisfait, est ce que la pression supplmentaire 30 au lieu de 24 psi n'est pa s trop dure l'amortissement roulage atterrissage?
Merci
bientt,
======= le 16/01/2006, 21:14:30 vous criviez: =======
Paul,
The max pressure mentioned on my original tyre was 24 PSI. As I was not confident in the strength of this tyre and wanted to increase that pressure, I replace it by a Mac Creary Air Trac 8.00-6/6 after 150 hours. I had to keep the original tube as the valve of the new tube I bought from ACS was incompatible with the Europa wheel. I inflate now at 30 PSI. The new tire and increased pressure greatly improves handling on both hard and grass runways. It also increases slightly the prop clearance. I have now 378 hours. The tyre does not show any sign of wear.
Remi Guerner
F-PGKL, S/N395 XS monowheel, 288 hours on a 914 + 90 hours since fitted with the 912S, Airmaster prop ordered.
I am wondering how folks are making out with Monowheel tires and tube life.
If I keep the tube inflation in the 18~20 psi then I find that it is really
tough on the tubes. Yesterday I had my second tube failure while on
landing. If you have ever had this happen is tough going, it is impossible
to move the aircraft by hand.
At this stage I am thinking of changing my tubes every 100 hours, but I am
wondering about the tire. The tire I have now has 370 hours on it and it
still has tread, how ever its obvious that the side walls have been weakened
by the constant running at low pressure, so perhaps I need to change it more
often as well. Thoughts ?
Paul
N378PJ
Michel Auvray
mau11(at)free.fr
05/02/2006
